SOURCE: Hooking up a klh PSW8-100 sub wofer
Hey you might find a solution on this audio and wiring blog: www.audioholicblog.com -- it has a blog about wiring your home audio system and the cables that you will need.
Hopefully this helps! Good Luck!
Dannyboy!
SOURCE: KLH ASW8-100b Sub woofer. I
Some specific model numbers might lead us to specific manuals and specific instructions. To find a manual, maybe run it by the manufacturer
Depends on your source and its amplifer complement. Some can drive a subwoofer directly while others just produce a Line Level subwoofer output for use by a separate amp feeding a subwoofer or self-amplified sub.
The set-up of the source to produce a subwoofer output is totally dependent on its design. Generally, you have to 1) tell it you have a sub, 2) define how bass will be routed or shared among your various speakers accordingto their bass-handling capacities, 3) using test tones, set the relative ludness and crossover settings so you have a uniform sound field.
