Replace the power supply boardv or mainboard @www.shopjimmy.com
This tv problems u have are only can be causes by only two boards 90% lightly it is the tv power supply board.5% it could be the tv Tuner signal board.5% could be both boards are dead require changes both boards.The tv power supply board it is the board that where the tv power a/c cord plug into it.The tv Tuner signal board it is the board that where the incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to by a whole refurbishes power supply board or tv Tuner signal board or both.
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
