TruTech PVS12701 Portable DVD Player Logo
Posted on Apr 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi- I have a portable dvd player, model PVS12701 that was purchased for Xmas '07. The battery doesn't hold the charge anymore. I read the answers from a couple yrs ago, but I just wondered if you had a more recent answer as to where I could purchase a new battery. Batteries Plus does not carry them. Thank you, Nancy
Theresa Worthington
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 16, 2015
Theresa Worthington
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
167
Points
Have you found a battery? I need one too and can't seem to locate one anywhere. It is like they fell of the face of the earth
Mark Sandmeyer
Level 1:
Problem Solver:
  • Contributor 24 Answers
  • Posted on Aug 25, 2015
Mark Sandmeyer
Contributor
Level 1:
Problem Solver:
Answers
24
Questions
Helped
8011
Points
40
Get hold of the maker give the model number and serial # . ,also try amazon. com
Anonymous
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Apr 06, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
19245
Points
312
I hahve searched all over for this battery. My only lead is this site
http://www.alcosupport.com/
one forum claimed that they found one here one. Sorry i couldn't be of more assistance, good luck!
1helpful
3helpful
My portable dvd charger isnt working anymore... i have to hold it and push it onto the ac socket so that it will charge but once it loosen up, it wont charge anyore. my portable dvd is still working since...
Hi my name is Roety,
I can help you with your issue ,
 You need to solder the DC jack, or replace the jack.
this will require taking it apart.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2answers
NEED A NEW BATTERY FOR MY TRUTECH PORTABLE DVD
Best Buy sells a couple different types of "Universal" batteries in their stores. They are by no means the exact same as the one you have connected now, but they will subside as a battery. If you were looking to get the exact same one that you have on the player now, you would have to contact the manufacture and order it directly from them. The ones that I am referring to from Best Buy have a variety of "plugs" in the package with the battery and you simply charge up the battery with the supplied charger and then pick out the "plug" that fits your particular unit and plug it into the charging slot on your portable DVD player.
1helpful
2answers
Battery
i recommend you take it batteries plus lookin you local phone book and they should be able to help they helped me find a battery for an hp laptop that was like 10 years old
Will not hold charge. LI-ion 7.4v. what,s wrong?
I have heard that if you run a LI-ion battery completely dead that it's gone. Does your unit work on AC? Is the connector loose? What battery number do you have?
2answers
Question
To my knowledge, a TruTech PVS12701 uses a Lithium-Ion 7.4v 2500mAh battery. There are no exact replacement batteries for this model. Best that you can try are batteries for some other brand of portable DVD players such as those for Samsung that has the same physical dimensions and electrical properties. Another factor to be considered is the cost of the battery. In some instances, it would be more economically reasonable to purchase a new portable DVD than just the battery. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Problem with Trutech portable player
It probably needs a new battery if it isn't holding a charge.
You can probably find them at Radio Shack or Batteries + stores.
3answers
Battery Charger for Trutech Portabel DVD player
As have been posted in a post of similar concern...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
