Won't play Dolby 5.1 sound from HD-DVDs, only...
posted by kgivens on Aug 06, 2008
Hi. I've got a A-30 hooked up to a Sony Ht-CT100 system via HDMI. The player had the original 1.0 firmware, but the problem I describe below has persisted even after updating the firmware to 3.0. HD-DVDs produce no sound whatsoever, even though when the disk starts playing, the LCD display on the Sony briefly reads "Dolby 5.1". But when I insert a standard-def DVD, the same "Dolby 5.1" notice pops up on the Sony, and the sound plays perfectly.
The only way I can get sound with HD-DVDs is to change the Audio setting on the Toshiba from "Auto HDMI" to "Downmixed PCM." (The other audio choice---labelled just "PCM"---also fails to produce any sound with HD-DVDs). I'm not happy with this as a long term solution, since it does seem to downgrade the positional quality to the sound effects.
Seems to me that Dolby 5.1 encoding should be the same with HD-DVDs and standard def DVDs. Not sure whether the problem is with Toshiba or Sony on this one. Any ideas? Thanks in advance---
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 08, 2008
Not Rated (0)
kgivens
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I tried that and it does work. However I hate having to run two cables (HDMI for the picture, optical out for the sound) to solve this problem---completely defeats the logic of having HDMI in the first place. Stupid.
Another drawback I'm seeing---with the optical out, I cannot get a great deal of volume out of the system, even on Max, when watching DVDs. TV audio can be made much louder. Irritating because I like to work out on various exercise machines when watching DVDs, and the equipment noise makes having a farily high volume desireable. Clearly something is being lost in the transfer.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Won't play Dolby 5.1 sound from HD-DVDs, only standard DVDs:
I don't want to Accept this solution
Solution #2
posted on Dec 07, 2008
Not Rated (0)
drumbanger
Rank:Wiz Wiz
Rating: 80%, 237 votes
try running a digatal out cord instead
Thank You!
Can you Help with these DVD Players problems?
Toshiba HD-A30 HD-DVD Player
i've lost my 5.1 s,s. on my tosh a30 hd dvd player,plays...
any the codes from toshiba tu onkyo recciver
hi, I got a toshiba HD-EP 10 dvd player as a present but...
Hi, Is there a unlocking code that will allow me to play...
I cannot play some DVD's on this machine, I need an unlock...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
TVs
(800) 575-9833
TV Parts for All Major Brands Genuine Japanese...
Acme Enterprises
TVRepairman.com is committed to helping you local...
TV RepairMan
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
