Acer CS-5530 Digital Camera Logo
Posted on Apr 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the CS-5530 support SDHC cards? - Acer CS-5530 Digital Camera
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Apr 05, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200478
Points
38521
No, only SD cards up to 2GB.
2answers
Can a panasonic dmc-fx8 use a sdhc memory card
This camera cannot be upgraded to read SDHC cards. The maximum is 2Gb Secure Digital.
1helpful
Unlock code nokia xpressmusic 5530
Get the unlocking code for your Nokia 5530 xpress music from http://www.simpleunlocking.com/ .This is the online service provider which offer the service for your mobile.After getting the code, follow the instructions here,
1 - Switch on your Nokia 5530 Xpress music without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5530 Xpress music.
3 - Compose
#pw+CODE+1#.
4 - The Nokia 5530 Xpress music would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5530 Xpress music mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose
#pw+CODE+7#.
2answers
Need to enter unlock code for nokia 5530
Follow the Unlocking instructions Below and Enter the Nokia 5530 model mobile.......
Nokia 5530 Xpress music Unlocking Instructions:Warning : Do not enter any wrong unlock codes on your Nokia 5530 Xpress music mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5530 Xpress music mobile phone, your phone may get hard locked and sometimes become unusable.
3 - Compose #pw+CODE+1#.
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5530 Xpress music
You can get the Unlock code and Instructions here
http://www.theunlockarena.com/nokia-5530-xpress-music/rs13wp9/
Nov 11, 2010 • Cell Phones
2helpful
My nokia 5530 is givin me problems.it won't tart up when the memory card is in place. the card has to b removed then it starts up. anyone knw why?
If you can try formatting the memory card. my 5530 had problems until i formatted the memory card so hope this helps.
2helpful
I just bought the Lumix DMC-ZR1 (yesterday April 3rd) When I put the memory card in, and it's blank, the camera reads that the memory card is full....how can I fix it??
In the instruction manual - see links below
  • It says DO NOT format on PC - you need to format in camera - have you done this? on Page 29 of the Manual http://panasonic.com.au/content/library/files/F002413.pdf
About cards that can be used in this unit You can use an SD Memory Card and SDHC Memory Card. •When the term card is used in these operating instructions this refers to the following types of Memory Cards. – SD Memory Card (8 MB to 2 GB) – SDHC Memory Card (4 GB to 32 GB) More specific information about memory cards that can be used with this unit. • You can only use an SDHC Memory Card if using cards with 4 GB or more capacity. • A 4 GB (or more) Memory Card without an SDHC logo is not based on the SD Standard and will not work in this product.
This is the instructions for the ZR1/ZX1 model http://panasonic.jp/support/global/cs/mpi/dsc/zx1/menu01.html
A number of manuals available from this site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZR1K
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
5helpful
MEMORY CARD ERROR
The 8GB card is SDHC, the FZ20 does not support SDHC only standard SD.
Here is the compatibilty list at Panasonic.
http://panasonic.jp/support/global/cs/sd/connect/dsc/dmc_fz20.html
Hope this helps.
Camera
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
1helpful
Caut display pentru acer cs 5530 digital camera. al meu s-a spart.
trage o privire aici, poate te ajuta http://www.ciao.co.uk/Acer_CS_5530__6113232
sunt tot felul de chestii interesante printre care si display-uri.
rate me
5helpful
4answers
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
2answers
Memory card
Make sure this card is a Secure Digital card; make sure the card is in correctly. Also, some of these Acer cameras use the older SD cards, and are not compatible with the newer generations.
Top Acer Cameras Experts
Ngoro
Tony Parsons
Tony Parsons
kelly
kelly
Are you an Acer Camera Expert? Answer questions, earn points and help others
