SOURCE: no water in icemaker
Please click on the blue links which are underlined to get more info.
Here are the check's which you can do:
Goodluck..
SOURCE: Freezer stops working for no reason
sounds like a defrost issue, see if theres a wire diagram id ck your heater/defrost circuit
SOURCE: freezer keeps iceing up on older kenmore bottom freezer top fridg
Hi,It is one of three things,
1:Defrost timer
2:Defrost element
3:Defrost thermostat
Please rate this solution
SOURCE: Kelivinator about 20 years old-
the fan is not working and needs to be replaced
Testimonial: "Thank you. I will call atechnician to fix it or can I do it? "
SOURCE: The fridge freezer has just stopped working,
This is likely going to require some electrical voltage testing. From what it sounds like, the fridge is getting power except possibly the compressor. You will want to test power to the compressor at least if not all of the components to see if something has failed or if it's just not getting power to a certiain component. There are usually relays in the electrical circuit as well that can fail.
Partselect,com has some neat diagrams that some people do find useful. Let me know if you need further assistance.
