My extention will now allow me to change the recorded name. I have changed the greeting but not the recorded name on the extention
If this does not work, log into your voicemail. Push 82. Then push 9. The old recording will play first then you can record your own!
Hope this helps! :)
Your name is in the Company Directory if you chose this option when you first set up your mailbox. To change it AFTER you set up your mailbox, press feature 9 8 1, enter your mailbox password, dial #, press ADMIN ( or 8 ), display should read
Mailbox admin
GREET PSWD QUIT
dial 1, at the tone record your name, press # to end recording, press # to accept, press RLS
It will look like you are re-recording your greeting but you are recording your " voice " name. Good Luck. ...Mike
