You can clear all the user data by holding your finger on the bottom right corner of the screen when turning on the satnav. Once the data is deleted you can set your home location by pressing WHERE TO and then GO HOME. As you won't have a home destination set it will give you 3 options
If you're at home, choosing option 2 is probably the easiest. You'll need to be outside so the satnav can access satellites. If you're not at home you can use option 1 or 3.
You can find the user manual for this satnav at http://static.garmincdn.com/pumac/2675_OwnersManual.pdf
