Hi, I'm trying to plug a AEG-Electrolux Lavamat 74800 into a converted outlet (110V to 220V) in Mexico, following a relocation to this country. Bought the washing machine in Germany which runs at 50Hz vs 60Hz in Mexico. E60 keeps showing up, also on the dryer. Is this due to freq?? Checked the electrical installation already twice to ensure adequate voltage and grounding. Called local Electrolux service and they mentioned freq should not be a problem... any idea what I should do? How do I reset the L74800?
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
The machine is only a year old and was working fine prior to the move. Interestingly enough, the dryer - Lavatherm 57900 - displays the same problem when plugged-in and turning the knob to any position after ca. 3 seconds
I have exact same problem with exact same combo under the exact consequences (relocated, converted outlet).
Did you manage to solve the problem? If so, how?
