Take the cart out and put it back in there might be some loose connection.
The error light flashing is caused by that bad or damaged cartridge. You can always try cleaning the electrical contacts on the cartridge and inside the ink
cartridge holder assembly, with a damp Q-Tip. Then dry the contacts with a new dry Q-Tip and retry the cartridge. If that does not help, and you still have
your old cartridge, try reinstalling it, even if its empty and see if that printer time out problem goes away.If it goes away replace the cartridge.
Hope this helps.
Shan
I did what you suggested but that did not cure the problem. What do I do next? Buy a new pringer? Nothing seems to cure the problem. Thanks for your help.
