If its charging on your computer,then the problem is the charger itself.
The first thing to do is try to check you charger and its terminal,pins might not in align or corroded,otherwise buy original sony ericsson charger.Also check the charging terminal of your phone. you can clean it using brush or a pin and scratch each portion so that the power voltage will some it.
