Apple iPod MA446LL/A MP3 Player Logo
Elisabeth Posted on Apr 05, 2017
IPod isn't doing anything.
My iPod hasn't been working correctly for the past few weeks, but I haven't worried too much about it until now. It would randomly come on and run the battery down. More than half of the time, when I would click on a song to play, it wouldn't play--just stay at 0 seconds. It always worked after a few resets with the center/menu button.
Today it isn't doing anything. It worked fine less than 24 hours ago, but now it's not showing up on the computer, nothing on the screen when I reset, not charging from my iTrip--nothing. We just got a new computer, and I don't have my music backed up. I'll do anything to fix it, I just don't know what's going on.
  • fb08 Nov 30, 2008
    My 30GB Ipod won't do anything. I replace the battery and when I plugged it in, the white apple came up, the menu came up, but it now won't do anything. On battery power, nothing happens
Kevin Shirel
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 21 Answers
  • Posted on Apr 05, 2017
Kevin Shirel
Contributor
Level 1:
New Friend:
Night Owl:
Answers
21
Questions
Helped
2130
Points
73
I need a little more information. What model of iPad do you have? This is a common problem on certain iPads but don't worry we may not get it working with out having to put in a new board but I will at least get your music transferred. If you want to keep it after I figure out what the problem is and if you like fixing your own things I will walk you through each step it may be easier if I make you a video to follow replacing the part I believe is causing your problem. I need the model number also I need to know how many gigabytes it has. One last thing since you can't power it up right now how many apps are you running on it. I don't think at this time that's your problem but it's something that will help me to narrow the problem down. Oh one last question have you dropped it and if so what kind of case do you keep it in IE. a otter case etc.
we will get you going soon.
kevin.
1 Related Answer
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Aug 05, 2008
SOURCE: unresponsive ipod?
Reboot your IPod by holding down on the center button while pressing the menu button. The Apple logo will appear.
If it still continues, reload your IPod software from Itunes.
Red screen
A popular trend as of late is sketching and designing on the iPad, iPhone and iPod. Maybe because of the versatility of these devices, maybe because it is so much fun; To make your designs even easier to work on and look better, try using a stylus. One of the best on the market right now is the iPhone Stylus Pen
Cannot download samsung kies to my cellphone
*Important Update 12-17-2010**
Over the past few months, thousands of people have visited this post in an attempt to sync their Samsung Captivate smartphones with their computers. As most of us learned, this isn't an easy task, and there just hasn't been a great solution. Although you could follow the instructions below and possibly get Kies to work, Samsung clearly explained that Kies is currently not supported by U.S. Galaxy phones.
2helpful
My LG LP1200DXR Portable Air Conditioner seems to be working properly, cooling the room as it should but no longer is draining any water. It does not shut off as it would when it is full although I have...
Actually, your unit was not designed for continuous draining. It needs water in the tank to help cool the coils. I'm sort of surprised that the unit hasn't stopped cooling or hasn't overheated. Since you haven't seen any water in the drain tank you have, it may have pasted the point of no return. Disconnect the hose, reinstall the drain plug and hope that you have to start emptying the tank again, soon.
Hope this helped you and thanks for choosing FixYa.
The gas gauge on my 92 Dodge Grand Caravan stopped working over the past two days. Two days ago it seemed to be fine. Yesterday it indicated that I had a quarter tank when it should have been 3/4 like the...
worth checking the fuel tank for holes or there might be some fuel delivery pipes leaking badly. Or it might be an O2 sensor not giving correct signal to ecu thus consuming so much fuel.
I need an Android 2.2 instruction manual, for a tablet I just bought (without useful instructions). Can you tell me where I can download one from? The Droid site download seems not to be...
Hi! I hope this is the manual you were looking for! Android is fairly intuitive, don't worry about messing anything up - you can't really, just browse around and learn. The guide isn't actually tablet-specific, because you haven't told me which tablet you have, usually the specific manuals are only on the manufacturer's site.
I have a 1990 LeSabre Station Wagon that hasn't been run much over the past 10 years. We have run it a little the past year and the air conditioner isn't working. I changed over the fittings to...
this is normal as there isn`t enough freon to keep the clutch on long enough to do anything thus lack of pressure in the system.also there won`t be enough freon and pressure in the system to show up any leak if there is one.
2answers
My HP 2035n printer makes a horrible, long beep noise whenever someone prints. Other than the noise the printer works perfectly, no errors come up, and nothing lights up or flashes indicating something is...
I've searched and can't find anyone else with this problem either, I know it isn't an instant solution but your best bet would be contacting their customer support.
http://www.hp.com/cgi-bin/hpsupport/index.pl
Ipod wont work
Ok, Not to worry... Try this out and let me know?
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Unresponsive ipod?
IPod Problems - Connecting to Windows / Songs Cutting Short
Sounds like Vista has some setting causing it to want to check all USB devices. Maybe a virus scan or something?
Yes restoring an ipod resets it back to all factory defaults, which is to sync automatically. So whenever you restore you will need to recheck that box.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
