Sony VAIO  VGN-TXN25N/B PC Notebook Logo
Posted on Feb 28, 2018
I change the laptop lowerbase ,i did pull out the HDD ,after i put everything back restart and my HDD not appear in bios and when i start the laptop its said no operating system . my laptop is sony vaio TXN25N.i think i put every correctly i know the hard drive is 1.8 ATA ZIP conector
5 Related Answers
Anonymous
  • 520 Answers
  • Posted on Mar 04, 2008
SOURCE: CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
Anonymous
  • Posted on Mar 27, 2008
SOURCE: SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Anonymous
  • 87 Answers
  • Posted on Jan 11, 2009
SOURCE: hard drive
Here is the Service Manual for you, hope it helps you.
Anonymous
  • 32281 Answers
  • Posted on Apr 15, 2009
SOURCE: Win Xp Drivers for sony vaio vgn-fw230j
Go to download the drivers that you require from the Sony WEB site, to their support/download page. Make sure you input your model laptop and select the Windows OS that matches your installed operating system.
Use this link :-
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DRIVER&SR=nav:service_support:electronics:drivers_software:esup&ref=http%3A//www.sony.com/index.php
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
  • Posted on May 05, 2010
SOURCE: DIP SWITCH BIOS RESET POSITIONS SONY VAIO VGN-fs660
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
1helpful
I have Acer TM 4150. I has booting problem like when i put on my laptop it gives message to boot from 1- floppy drive 2-HDD 3- Cd Rom also in Cmos it shows no Hard disk or O HDD i restart it again...
Isssue with your Hard Disk... Possibility Data lost, due to power lost, or Bios Battery need to be change... To do So, Press and hold del button while you turn on your Laptop this wil bring you inside you Bios then Check carefuly set date and Time also set autodetect hard drive and set cd-rom first hard disk 0. second then the rest off... press F10 to save your change then restart your laptop then see if it will boot from itself.. if not ...Then put your XP CD on the cd-rom then re-start then press F-12 then chose Cd start to re-install your windows make sure you have your Cd key first then from anoter computer go on the net and download all your drivers for your laptot type down the model off your Laptop then on any browers type exemple; download ACER TM4150 drivers for xp or the one you use.. sample is that.. Good Luck
HDD PASSWORD
Pulling the battery out will NOT solve anything.
On bios it should say;
"If you lock your Hard Drive with a password, you will not be able to access it even if you put it in another Computer"
3answers
Hard drive will not boot.
try to install with other sytems and check the data cable
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
No disk drive???
Check HDD in the bios.
Restart Laptop and keep ressing F2. In the bios screen you will see HDD or Primary IDE and value next to that representing it's size. If that is not detected in the bios you need to replace HDD
2helpful
2answers
Error message Non system disk error replace and strike any key wh
Hi !
This error means either there is no disk (or disconnected/wrong connected) or your HDD is gone (which I don't believe) !
I can't find a reason why you pulled out your HDD when it was (I assume) working good before ?!?
Anyway, . . .now, please check carefully the connectors - both sides, to the HDD and to the Board(if any), if they are properly fit!
It is an IDE disk and there are two groups pins on the HDD. Check the pins if they are all going to plastic male connector (and then to the board.
A group of 4 or 6 pins on HDD should not be connected. There is one pin missing in (about) middle of the second row of pins - it is o.k.
Put your ear close on the chasis of laptop and find if there is a spinning noise when you turn your laptop on.
If there you can hear noise, then check in BIOS if your HDD exists.
If not, try to check it on another Laptop/PC.
Regards.
Thinkpad T20 2647 HDD problem
on restart enter setup or bios and set to default settings
then restart and press f7 choose option to boot from cd
then press enter should boot.
if not then this is the site i use for bios updates www.wimsbios.com
don't forget to rate me
thanx
2helpful
Hdd password reset
Do one thing remove the battery of the laptop in the back side of the laptop after the swicth off your laptop then put in after ten sec and restart the laptop hadd password will be access and bios password also disable.
or do when you start the laptop then press the del button up to ten sec you get it bios setting page after that there is give supervior password give enter twices time your password will be disable.
15helpful
7answers
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
