Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Posted on Aug 05, 2008
Hotpoint aquarius+ fdw75
Was coming up with a10 on diplay and now when you start a cycle there is a dry girgling sound and there does not seem to be enough water coming through.
  • Cooroo Jan 02, 2009
    Everything but the prewash stops after about 2-3 mins and A10 comes up. However, water seems to be going in and out of the washer fine. Prewash works perfectly.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
393
Points
Http://www.howtomendit.com/answers.php?id=13831 look at this, we have same problem and on here it states - AL01 - Anti flood switch operated.... so worth looking into before calling engineer out
2helpful
2answers
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
My Aquarius FDW70 keeps coming up with code A10
Dear sir,
If your dish washer is type EV02 Module,
Error A10: means Faulty fill valve.
Check valve and associated wiring.
If your Dishwasher is
Standard Module + FDW70 + FDW75,
E10 means Heater fault.
Check heater and associated wiring.
i think it helps for solve your problem.
if you have any doubt regarding this issue leave a feedback we will glad to assit you.
Have a nice day
good luck
Sep 12, 2009 • Dishwashers
15helpful
Instruction Manual for Hotpoint washer dryer wd420
Try this link:
http://www.hotpointservice.co.uk/hs/pages/manual/manual/search.do
Enter the model number in the search box, and download instructions.
Please rate my solution.
Thankyou.
Dryer not drying clothes
If you remove the lid you will see the element on top of the drum.
There are a couple of thermal cutouts mounted on it which would be the first thing to check.
Also look for the obvious broken wires etc.
Also can you hear the fan running when machine is in operation?
Hope this helps & thankyou for using Fixya.
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
2answers
Hotpoint Aquarius WD640 Progressive problems now causing flooding
Normally if it leaks then the one way valve in the back of the machine is clogged, you remove the back, undo the jubilee clips on the 3" black hose & clean the ball.
2helpful
2answers
Hotpoint Aquarius wd440
Find the pipe that comes out of the bottom of the drum, this may contain coin, muck, etc. Clean. This pipe leads to the small pump that draws the water out. If your clean of the pipe does not work the machine.......there could be a fault with your pump..........which you can/cannot clean.
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
