SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
SOURCE: Error on printer
There is a safety lock on the scanner that may be in the locked position. Turn the unit off and locate the green lock lever/switch under the scanner where the paper comes out. It will be labeled with a icon (picture) of a lock (unlocked and locked). Move it to the unlocked and locked position multiple times, ending up in the unlocked position. It may be stuck so moving it back and forth may release it. Turn it back on and try it.
SOURCE: keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
SOURCE: How do I replace the tray 1 pick roller for my
Take out the tray, and you will find a pick rubber roller at the base.
Even you may clean and use it.
SOURCE: samsung clx-3160fn deve home sensor error
Dev. Home error can be fixed by stretching out a solenoid spring on the
power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
