Back to:
Tags:
Yamata FY811 Mechanical Sewing Machine
Machine mechanism not moving
posted by lilyjd on Aug 05, 2008
I have a domestic Yamata FY811 sewing machine .I can hear the motor running but the outward mechanism like the needle,thread take up lever etc., are not moving. Could you kindly tell me what to do please.......
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 05, 2008
FixYa! (100)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1418 votes
Check the stop motion to make sure it is tight, check the motor belt in case it has come off or broken, if the belt is okay check the motor pulley in case it has come loose.
Rating Locked! (?) lilyjd has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on machine mechanism not moving:
I don't want to Accept this solution
Can you Help with these Sewing Machines problems?
Sewing Machines
have a kenmore model 1774 older machine and the bobbin...
Sewing Machines
the bottom thread keeps breaking on my sewing machine I...
Sewing Machines
I bought a used pfaff 4760 hobbylock and found out it was...
Sewing Machines
The machine does not disengage the sewing platform and...
Are all bobbins insert the same way in a industrial...
Loading problems.
Repair Service
Find Sewing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
