From what you described, it sounds like your carafe isn't fitting properly. The lid of the carafe is supposed to open a valve on the bottom of the filter basket. If this valve is clogged or not opening completely, that will produce your symptoms. Also, the warming element will not keep carafe hot if the carafe isn't sitting properly.
SOURCE: filter basket
You can find ODC325s on ebay just for parts since the heating element is shot. I don't believe those parts are for sale anymore.
SOURCE: Water and coffee spilling from Filter Basket onto counter?
We used to have the same problem! try a better brand of coffee filter! It worked for us? Also make sure that the filters are not doubled up!
SOURCE: filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
SOURCE: Coffee maker will not let water go into coffee
run pure white vinegar through instead of water--at least 3-4 cycles just reuse same vinegar then discard run one pot just water--if machine is just plugged that should solve..
SOURCE: coffee leaks all over the counter every time
I had this problem after about a year of use. The thermal carafe lid had become clogged enough with coffee sludge (fine grounds/oil) and hard water deposits to slow the flow through the lid. I soaked the lid in a bowl of 2 cups hot soapy water + 2/3 cup white vinegar for a few hours, agitating the lid in the mixture every 1/2 hour or so.
Then, I rinsed the lid and packed baking soda in every opening and dropped it back into the mixture - hoping the fizzing action of the baking soda+vinegar would help loosen any remaining sludge.
I rinsed it again, and whacked it against the side of the sink for a final effort to loosen sludge. Repeated the baking soda + rinse + whacking a couple of times. No more problems.
In the future, I plan to do the soak at every Cleaning cycle/every couple of months.
Or, if you don't want to deal with it, replacement thermal carafe lids are available from Cuisinart for $6 + shipping.
