It is possible that the board is bad. A loose connection orlow voltage issue may also cause this problem to occur. If the voltages arewithin the acceptable rand and all connection are tight then remove any accessoryequipment and restart the unit to see if the problem continues. If it does thena new board will probably resolve the issue.
You can find answers to common spa problems online at http://www.balboadirect.com/support.aspx
Hope that helps!
