Buffalo Technology Buffalo DriveStation Combo4 Hard drive 2 TB external FireWire FireWire 800 HiSpeed USB USB 20 Logo
Posted on Apr 02, 2011
My buffalo combo 4 2 TB wont show up on my xbox 360. I already have it formated FAT32
silentbob417
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Apr 05, 2011
silentbob417
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
5048
Points
13
The Xbox 360 can only recognize drives up to 16GB as noted on their website, I myself have tried a 32GB flash drive to test the limitations and it was not recognized. At this time it seems as though microsoft is limiting their external storage to 16GB.
http://support.xbox.com/en-us/Pages/xbox-360/how-to/usb-flash-drive.aspx
Www xbox com support
Cause that game needs a new dash.Check what dash you are currently on by going to system settings and system info you will see the kernel there .it most likely is an old version so download this one( http;//download.digiex.net/Consoles/Xbox360/Dashboards/2.0.16747.0.zip)
1.) Unrar the download (i use winzip)
2.) Copy the $SystemUpdate folder to the root of a pc formatted USB Stick (The memory stick must be FAT or Fat32 formatted)
3.)With that extracted folder now on your USB, Insert the USB Stick into your Xbox 360 console.
4.) You will be automatically prompted to update with a USB stick. Power down the 360 and power it on again. You should be ask to update before the 360 boots to the dashboard.Click yes and wait for it to install then shut down.
5.) Once the update is complete your Xbox 360 will restart then boot up to the new dashboard.
tip
Play videos on Xbox 360 and stream videos to Xbox 360
How to play videos on Xbox 360 and stream videos to Xbox 360 – including Blu-ray, DVD movies, and videos in various file formats
This tutorial intends to list out all the video formats supported by the Xbox 360, and explains all the available ways to play videos on Xbox 360 in HD quality or stream videos to Xbox 360. The videos include Blu-ray movies, standard DVD movies, and various other videos, such as ISO image file, Camera footages, MKV, MTS, VOB, M2TS, TS, TP, FLV files, etc.
Let's Get Started.
Part 1: The details of Xbox 360 supported file formats
1. AVI:
File Extensions: .avi, .divx
Containers: AVI
Video Profiles: MPEG-4 Part 2, Simple & Advanced Simple Profile
Video Bitrate: 5 Mbps with resolutions of 1280 x 720 at 30fps.
Audio Profiles: Dolby Digital 2 channel and 5.1 channel, MP3
Audio Max Bitrate: No restrictions.
2. H.264:
File Extensions: .mp4, .m4v, mp4v, .mov
Containers: MPEG-4, QuickTime
Video Profiles: Baseline, main, and high (up to Level 4.1) profiles.
Video Bitrate: 10 Mbps with resolutions of 1920 x 1080 at 30fps. Audio Profiles: 2 channel AAC low complexity (LC)
3. MPEG-4:
File Extensions: .mp4, .m4v, .mp4v, .mov
Video Profiles: Simple & Advanced Simple Profile
4. WMV:
File Extensions: .wmv
Container: asf
Video Profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main, and advanced up to Level 3
Video Bitrate: 15 Mbps with resolutions of 1920 x 1080 at 30fps.
Audio Profiles: WMA7/8, WMA 9 Pro (stereo and 5.1), WMA lossless
Notes: You can not mix and match the video and audio codec outside of the above defined lists randomly.
Part 2: Different ways to play videos on Xbox 360
With regard to playback videos from a USB storage device, please note that the Xbox 360 will support as big of a storage device as you can format using FAT32, and the maximum size of any single file on FAT32 is 4GB. Besides that, the maximum file size for an AVI, MPEG-4 Part 2, and H.264 file that can be played is 4 GB as well. To play a file greater than 4GB on Xbox 360, you can use Windows Media Player 11 and the Zune software to stream videos from your PC to Xbox 360 console, and notice that the file format must be WMV only. Why is it so special with a WMV file? That maybe WMV is a codec developed by Microsoft.
Well, that is to say, to some extent, we can consider WMV as the optimal format to play or stream to Xbox 360. When you are gonna watch a Blu-ray/DVD movie, or an MKV video, or some files else that are out of the range of Xbox 360 workable formats, what is your solution? We usually make use of Pavtube Blu-ray Video Converter Ultimate to do format conversion. Why do we choose it? Mainly because of its splendid output quality and its feature of an all-in-one application: a Blu-ray ripper, a DVD ripper, and a versatile video converter.
Part 3: How to convert Blu-ray/DVD and videos to WMV for play/stream on/to Xbox 360
We have mentioned in the above contents that the program we will use is Pavtube Blu-ray Video Converter Ultimate. Go to find a step-by-step instruction from the following part.
STEP 1: Load Blu-ray, DVD or other video files into this program
Click "Add Video" to import video files, and click "Load DVD" to import Blu-ray or DVD files.
STEP 2: Select subtitle and audio track
Click on the pull down menu after "Subtitle" and "Audio" respectively to select your needed subtitle and audio track as your choice. Your selection can be reviewed in the preview window to the right hand of the main interface.
STEP 3: Select WMV as output format for Xbox 360
Click on the drop-down list at the opposite side of "Format", and then choose "WMV3 (WMV9) (*.wmv)" as output format.
STEP 4: Do optimal settings for the output WMV files
Click on "Settings" button, and afterwards you can adjust audio and video parameters including video/audio codec, resolution, video/audio bit rate, frame rate, sample rate and audio channel on the popup window. To make it excellent for playback on Xbox 360, you can follow the optimal settings as below:
Video codec: wmv3 (the default one)
Resolution: 1920*1080
Bitrate: 150 kbps
Frame rate: 30 fps
Audio codec: wmav3 (the default one)
Sample rate: 48 khz
Bitrate: 320 kbps
Channels: 5.1 Channels
Do remember clicking "OK" button to confirm your settings.
STEP 5: Click "Convert" button to start BD/DVD ripping or video conversion
Once finished, click "Open" button at the bottom to get the output WMV files for Xbox 360, which now is prepared for playback or streaming.
Part 4: How to stream videos to Xbox 360
Well, as we have mentioned in Part 2, there are at least four ways to stream videos to Xbox 360, from Windows Media Center, Windows Home Server, Windows Media Player 11, and Zune Software. Actually, lots of online articles have detailed the setups and operating steps, just check the following links to find the one which is most suitable for you:
How to stream videos to Xbox 360 via Windows Media Center
How to stream videos to Xbox 360 via Windows Home Server
How to stream videos to Xbox 360 via Windows Media Player 11
How to stream videos to Xbox 360 via Zune Software
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Xbox360 wont recognize my western digital passport external hard drive
Make sure the harddrive is formatted to FAT32, otherwise the 360 won't read it.
2helpful
When plugging in to xbox 360. it doesnt recognise the hard drive so i cant play films or music
If you have the latest elements drive, it may be formatted to NTFS. The Xbox 360 cannot read NTFS, so the simple solution would be to format it to FAT32. The problem, would then be that you cannot transfer files larger than 4GB or a folders with more than 1000 files to a FAT32 drive.
Hope this helps
Unable to play a movie from a memory stick
The memory stick must be formatted to FAT32 and the video files have to be supported by the Xbox 360, AVI and WMV work for sure, Xbox's website has more formats listed. Hope it helps!
2helpful
Iomega 1tb select wont be detected by my xbox 360 and philips DVD player, but will be found no problem by my Toshiba Equium laptop running vista
Check if the disk is formatted in fat32. Some devices won't detect hard disks formatted in another format.
1helpful
4answers
Wd passport will not load to my xbox 360
Re: My passport Elite 500 will not show up my Xbox360 Options 12-30-2009 11:19 AM
if it's the drive that comes with the smartware, then it comes pre-formatted NTFS , and your xbox needs FAT32 format to work.
So, you need to connected this drive on a mac computer to format to ms dos FAT32, or use a formatting utility like "partition magic" to format the drive to fat32, then if there's password assigned remove it, and it should work
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
