SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
SOURCE: camper electrical wiring and propane lines dont work
you need to find the propane lines and where ever you have a joint you need to put "snoop" on it. which is basicly soap and water sorry my spelling sucks. anyway you do this with the propane on and whereever you have bubbles you have troubles. you can even check your lines with it. Now yoiur electrical woes can be fixed by tracing your wiring and finding out where you have a short this is when two wires are either touching eachother both of these problems take time and they take some experience. If you mess this up you could blow yourself up. Let me know what you are going to do. I'm worried for you
SOURCE: 15 AMP versus 20 AMP outlet plug
The circuit is protected by the 15 amp breaker. That's what matters, the wire size and the breaker feeding it. It's OK to have a 20 amp recepticle fed by a 15 amp breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Testimonial: "Concise answer"
SOURCE: factory trailer connecter for trailer plug in - no current
Also try http://www.etrailer.com/faq-wiring.aspx. They have a great website with lots of info. Check ground.
