SOURCE: m-audio pro 88 keyboard
When you turn on your keyboard, you have to make sure that your foot isn't on the pedal because that will cause the notes to be sustained. Just wait until the keyboard is on to push the pedal.
To install your keyboard or mouse:
To install the device driver from the Gateway System Restoration Kit:
The keyboard does not work
Make sure that the keyboard cable is plugged in correctly.Remove all extension cables and switchboxesTry a keyboard that you know works to make sure that the keyboard port works.Clean the keyboard by using an aerosol can of air with a narrow, straw-like extension to remove dust and lint trapped under the keys.Try a keyboard that you know works to make sure that the keyboard port works.Reinstall the keyboard device driver. For more information, see Installing the device driver.
A keyboard character keeps repeating
Make sure that nothing is resting on the keyboard.Make sure that a key is not stuck. Press each key to loosen a key that might be stuck, then restart your computer.
Liquid spilled in the keyboard
If you spill liquid on the keyboard, turn off your computer and turn the keyboard upside down. Let the liquid drain, then let the keyboard dry before trying to use it again. If the keyboard does not work after it dries, you may need to replace it.
