You can print a printer status report,print self test page from printer as standalone.there are details mentioned there about the page printed by your printer since you set it up.Page count started from the first time printer prints anything when you set it up and it collates all of it till present.
You also need to consider the ype of printer you have.
You can also print test page from PC to printer
this is example for windows xp.
windows xp is printers and faxes
windows vista is hardware and sound then printers
windows 7 is devices and printers
Learn how to print a self-report page from the product with Windows.
Printing a self-test report from Windows
NOTE:
The
exact steps to open the Printers or Printers and Faxes window might
vary depending on the version of Microsoft Windows being used.
Checking replaceables
If you experience frequent paper jams or printing problems, check the
number of pages the machine has printed or scanned. Replace the
corresponding parts, if necessary.
1. Press Menu until System Setup appears on the bottom line of the
display and press OK.
2. Press the left/right arrow until Maintenance appears and press OK.
3. Press the left/right arrow until Supplies Life appears and press OK.
4. Press the left/right arrow until the item you want appears and press OK.
• Supplies Info: Prints the supply information page.
• Total: Displays the total number of pages printed.
• ADF Scan: Displays the number of pages scanned using the ADF.
• Platen Scan: Displays the number of pages scanned using the
scanner glass.
• Imaging Unit, Transfer Belt, Fuser, TransferRoller, Tray1
Roller: displays the number of pages printed each item.
5. If you selected to print a supply information page, press OK to confirm.
6. Press Stop/Clear to return to ready mode.
when you reach the imaging unit reset it then try, it should work then
