Question about AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine
I am trying to record my personal greeting on my message machine with the DECT 6.0...can you please explain to me how I can record my greetings?
  • AT&T Master
  • 6,004 Answers
Which model phone do you have? For the CL82509 and related DECT 6.0, you need to set the outgoing message from the handset when the answering machine is on. (It can be turned on from the handset).
For the outgoing message: with the handset in Idle mode, press Menu/Select. Use the up (Dir) and down (CID) arrows to highlight Ans Sys Setup. Then press Menu/Select. Use the same arrow keys to select Announcement and press Menu/Select again. Press 7 to record a new announcement. At the tone, speak your message clearly then press 5 when you have ended the message. The message will play back.
This model's manual is available here: http://att.vtp-media.com/ecp/documents/product_Product/132/UserManual/5995/cl82509_manual_USA_i6.pdf . See page 15 to set the answering system outgoing message. (This is different than Voicemail. To set up Voicemail, you will need to see your telephone provider's documentation.)
Most AT&T phone manuals are available here: http://telephones.att.com/att/index.cfm/product-support/manuals/ .
I hope this helps.
Posted on Apr 01, 2011
Blackberry9650 verizon
Posted on Apr 22, 2012
  • Maxamed531 Apr 22, 2012
    No internet my phone blackberry9650 in kenya
SOURCE:
Setting up answering machine for UnidenDECT 6.0
To replace the default greeting with a personal one
( Uniden model D1680 & similar ):
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Record Greeting" then press [select]
4. It will display & tell you aloud to press [select]
5. Speak Clearly your desired greeting, then press [select]
6. press [END] to conclude & exit
Apr 18, 2015 | Uniden DECT 6.0 Cordless Phone
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I lost manual. I need to know change message when will be out of town answering message.
announcement.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Dec 03, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do i change my vociemail message for the Dect 6.0?
Reording a Personal Greeting Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting.
To keep this greeting: Do nothing.. To switch to the other greeting: Press 6 while the system is playing the current greeting. Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last greeting you hear is used as the current greeting.
Deleting Your Personal Greeting You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous section to switch the greeting.)
While the personal greeting is playing, press 4. The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Oct 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
May 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
I recently bought a dect 6.0 digital answering system,and a friend put the first message on for me,then lost the manual,and now I can't figure out how to record a new message.Help!
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
  1. Press the Message icon (letter)/mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
I am unable to record my message on my Uniden DECT 1580 phone. It tells me to go to command 8:RECNEWGREETING. My question is where the hell do I find command 8?? Jesse
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Press /mute on the handset. The system announces the number of new and old messages, and then starts to play the messages unless it has no messages.
You will hear intermittent beeps indicating that the system is in the command-waiting mode.
Press /mute.
Oct 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine Logo
1,422 people viewed this question
Top AT&T Lands Phones Experts
Ekse
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
