You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (
Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press
Black Start or
Color Start.
The machine starts scanning the
document.
Note
• To cancel, press
Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
Press
Black Start or
Color Start.
If you press
Black Start, the
machine starts scanning the first
page. Go to step e.
If you press
Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press
2 to
choose No. (or press
Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press
OK.
starts scanning the page.
I have exactly the same problem. Can anyone help? The last comment was not helpful. I have tried deleting memory data but this has had no affect.
won't sent fax *memory* - set doc
