I can presume that your monitor is turned ON or at standby power supply all the time 24/7. That makes the power supply is always availabe on circuit boards.
1. check the data cable or switch to new one...
2. Open your monitor there is data bus cable connected to LCD monitor from circuit board. clean it with CRC cleaner.. beware that the spray is done only and only on the socket of that cable....
3. Reinsert that cable and check again...
I think that due to continuous operation of LCD monitor some carbon has been deposited inside the jacket.
SOURCE: My SOny SDM-S204 has no green in the computer
Hello amellows, hi, check the video cable for loose connection, tighten the vga plug screw, try to wiggle the vga plug and see if there are changes on the display. As for the monitor menu, this is usually not affected, the colors are built in its onboard memory.
