You can get instructions for your watch from the Fossil web site.
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Click on this and a list of diagrams and watch descriptions will appear,Download
Unfortunately they do not list their instructions under model numbers, so you will have to run your cursor over the sets of instructions (the diagram will change as you do this), until you find the one that matches your watch.
Actually there is no instruction manual for ME1020 available on Fossil website except for how to replace the battery. When you try to match ME1020 model with the available diagrams, there is no match (4 eyes).
To set the time, pull the crown out to the second position. Now set the min/hour hands. Date hand is linked to it so keep rotating the crown till the date is set is set correctly. Now remaining is the day setting. Notice that the day changes every 24 hour mark on the 24 Hour sub-dial, so cross this mark to change the day. Go reverse & again cross the 24 hour mark to get the next day. Repeat this till you get the correct day setting. Now your day is also set along with date & time!
Turn the crown either clockwise or counter-clockwise and set the date for the previous day. The direction that moves the date varies on different watch models.
Analog Automatic: Time and Date Setting
Pull crown out to position 2 and rotate clockwise to set time.
Pull crown out to position 3; date will advance automatically. To set to required date, continue to rotate crown between positions 2 and 3.
Push crown back to position 1.
Analog Digital: Time and Calendar Setting
Press and hold pusher A for 2 seconds to enter setting mode. Year will begin flashing.
Press pusher A to select year, month, date, hour, minute, second, and then exit setting mode.
Press pusher B to adjust digit.
Press and hold pusher B to adjust digit automatically.
If no pushers are operated for 30 seconds, setting will be returned to Normal Time Display.
These are the three most common Fossils. If yours isn't here please let me know which model you have and I'll get you the instructions. Hope this helps.
1. Pull out the time set mode button. 2. Press the upper right button repeatedly until the sweep hand makes it back to 00/60. 3. Press the time set button back into normal position.
hold the left, bottom button (marked ....) for a few seconds....then
press the top right button (marked with 1 dot) to change between the
hour, minute, date etc. use the bottom right button to advance the
flashing number, and when finished setting time and date, use the
bottom left button to stop the numbers flashing and return the watch to
normal. hope this helps, this is also how to change the date for the
other question asker (works on 2 other starck/fossil watches i have and
i assume the controls are the same).
Finally i got it while playing around with my fossil JR9455. . . Here's the step by step method in setting the time: 1. press and hold light button and press start/split button (light and start/split are both pressed by this time) 2. you should hear a beep 3. You should notice that the display changed 4. press mode to choose which setting you want to change 5. to change the values, just press start/split button to move up and reset/stop button to move down 6. to finish the setting just press light button again. This method worked with my watch. I hope this helps. . .
Alot of times on watches you can click on the stem one time and you can change the hour. Click on the stem and you can change the minute, date, and month.
