If the power button on your Nokia C200 is not working, there are a few steps you can try to troubleshoot the issue:
Check for physical damage: If the power button is damaged or broken, it may not function properly. Inspect the button for any visible damage or debris that may be preventing it from working.
Clean the button: If the power button is stuck or not responding, it may be due to dirt or debris lodged in the button. Use a small brush or toothbrush to gently clean around the button and see if this resolves the issue.
Check the button connections: If the power button is not working properly, it may be due to a loose connection or malfunctioning component. Check the connections between the power button and the rest of the device to make sure they are secure.
Reset the device: If the power button is still not working after trying the above steps, you may want to try resetting the device to its factory settings. To do this, go to "Settings," then "Backup and reset" and select "Factory data reset."
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
While holding down the "Power" button, release the "Stop/Reset" button.
Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
Click the "Stop/Reset" button four times
Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Hello Remove the error code 5100 1. Turn off printer. 2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color. 3. let go button Stop/Reset, continuing to hold POWER. 4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons. 5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key) 6.turn off printer by POWER button, then turn on. 7. You should be set. If it didn't work, try it again, slowly. It WILL work! Hope this helps, if so do appreciate my effort by rating the solution Good Luck, Cmptrlink
error 27??? you can reset your printer.. 1.with the printer powered off but connected to a power source,press the power button while pressing and holding the stop/reset button. 2.when the power is lit,press the stop/reset button two times while pressing and holding the power button. 3.when releasing the power button and stop/reset button(regardless of order),the printer will move into service mode.(wait for menu selection) 4.when the on/off light is green,press stop/reset button the specified number of time(s)according to the function listed in the table below..(each time the stop/reset button is pressed,the led lights alternately in orange and green,starting with orange.) note:press 4 times for waste ink counter reset.. if did not work try more.. not work again you can change the sponge...
In service mode. Put Stop/reset 4 times orange => reset waste ink. Put stop/reset 8 times orange => set level ink.
And try this. 1)With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button. 2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
For me, it worked when I did this: 1) With the printer powered off but connected to a power source, press and hold the Stop/Reset button for 4-5 seconds. 2) Without letting go of the Stop/Reset button, press and hold the Power button. Then, press the Stop/Reset button two times without letting go of the Power button. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
For me, it worked when I did this: 1) With the printer powered off but connected to a power source, press and hold the Stop/Reset button for 4-5 seconds. 2) Without letting go of the Stop/Reset button, press and hold the Power button. Then, press the Stop/Reset button two times without letting go of the Power button. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping. All The Best: Pineworks
