Question about Canon PIXMA MP530 All-In-One InkJet Printer
Ail.comI have a canon K10269 (PIXMA MP530 ) Itried to print a document and kept getting error 6500 and the alarm lamp was flashing. I opened the cover to replace the cartridges but the cartridge holder did not position itself. I tried several times but the cartridge holder does not move at all. Help me please
    Habit-Forming:
  • 168 Answers
The error code of 6500 is a PCI bus error and this is a Service Error Code.
Typically this is an internal error of one of the ASIC chips on the logic board and
can only be repaired by replacing the logic board.
Posted on Jan 27, 2018
  • Canon Master
  • 10,318 Answers
PIXMA MP530
Linke to manuals, and free Canon telephone number and email support.
SOURCE:
geemarie
  • 876 Answers
SOURCE: Error 5100 for canon mp530
I would do all of the following and see if yo can clear this code. It is not on any Canon list of possible codes, so I have no idea what it means., but let's do this:
Turn off the printer and unplug it.
Remove the print cartridges. Look at them, are they leak free? Look into the cartridge holders. Are they clean?. Dried ink or blobs should be cleaned off with a little alcohol and a qtip.
Are the little wire holders bent or broken? Do they look exactly the same?
Turn the printer back on reinstall the cartridges.Check in your printer preferences/services and clean your cartridges.
Now turn it off again and unplug it. Open the paper jam door and gently push the paper roller forward until it clicks. At the same time, look for even the tiniest scrap of anything in there.
Close the paper jam door and plug your printer back in. Restart your computer.
If the problem is not solved. You may need to reinstall the printer. Do You have your original disc? Be sure to do a clean install. ( Turn off all running programs in the lower right corner including your virus control. Also go to Toolbar>tools>internet options>general>and delete all you cookies and temporary internet files.) Turn off and unplug your printer.
Reinstall the software. When it is finished if it has not told you to plug your print back in do so now. Restart your computer and turn your printer on.
I hope this helps. Good luck to you.
Posted on Aug 24, 2008
SOURCE: My canon printer Pixma mp530
the problem is 5C10.
What's that?
Posted on Aug 21, 2010
  • 118 Answers
SOURCE: I have a Canon PIXMA MP530 printer and showing an
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
Posted on Mar 02, 2011
Ree MMS
  • 51 Answers
SOURCE: pixma mp530 6500
... whats the problem exactly
Posted on May 26, 2011
Ree MMS
  • 51 Answers
SOURCE: canon mp530 pixma check printer
It may be the cartridge...try removing it and then reseating it. If that doesn't do it, clean the contacts with water or isopropyl alcohol.(power off when you do this)
maybe this forum will explain more
http://www.fixyourownprinter.com/forums/laser/13864
Eror p2
the web address for the manual is "http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp250#BrochuresAndManuals"
look for this document "mp250sosmwin110us.exe" install it and then look for the "troubleshooting" on the right side of the window and follow the instructions. the path is (MAIN WINDOW) >
Troubleshooting
An Error Code Is Displayed on the LED
Power Lamp Flashes Green and Alarm Lamp Flashes Orange Alternately
(go down the page until it says: Power Lamp Flashes Green and Alarm Lamp Flashes Orange Alternately )> then look for the error code. good luck!!sorry, the system is printing the same font as the book.
Apr 14, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a Canon PIXMA MP530 printer and showing an Service Error 5C10. What is that error? It will not print and the Alarm light flashes.
Rob
Mar 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Feb 19, 2011 | Canon PIXMA® MP530 All-In-One Printer
My Canon MP530 is giving 6A00 error message and alarm light is flashing along with copy button. i have replaced empty ink cartridges with new ones. Can anyone help, please?
Error code 6A00 indicates an error occurred in the AP motor during purging operation. You need to replace sheet feed unit, logic board assy and purge unit to fix it. Before replacement of the logic board assy, check the waste ink amount (by service test print or EEPROM information print). If the waste ink amount is 7% or more, also replace the ink absorber kit when replacing the logic board assy.
Feb 09, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error 6500 on a Canon MP500
choy ada yg tahu printer canon pixma mp500 error code 6500 g y? please help me
May 12, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My CANON PIXMA MP530 is showing the alarm, "Document in ADF."
Open the top cover of the ADF and look for a rectangular hole with a lever stuck down. That lever should only go down when a paper is placed in the feeder, and sometimes they get stuck in the down position. A bent paper clip might help you lift it gently...
Jun 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
MP530
The alarm light is blinking. It says Error 5200? What is that?
Email me at : eunice@idig.net
Sep 09, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Jan 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
100 people viewed this question
Clive
Clive
old marine
old marine
Ekse
