SOURCE: my htc touch pro wont turn on after being charged all night
Had the same problem. You need new battery! (borrow from friend, if anyone has HTC to test if phone is OK with different battery).
Testimonial: "holy crsp it worked thanx:)"
SOURCE: cant charge my htc p3300 phone
you must have disabled that option, go to settings select power and there will be an option ie. "when device is turned on" deselect it.
SOURCE: I have a HTC HD2.
you should try to have it opened and inspected for mostly water damage. all those indicate to a fault motherboard. some components are shorting and causing the battery drainage.
this will require disassembling phone and be sure, this is a hardware problem not software.
regards
SOURCE: charged battery fully fitted to phone discharged
HTC Phones are known for short battery life if you are using it only expect 2-4 hours
If you are not using it at all and have turned off wifi 3g the screen music and background apps and don't make any calls/txts expect as many as 18 hours.
