Question about Polycom SoundStation
The battery in our Polycom Soundstation 2 w died. we discovered that battery had been recalled. we received a new one after several weeks. when we put the new battery in the polycom it worked but when you try to make a call you get a busy signal before you can even finish entering the number. can you tell me what is wrong?
SOURCE:
SOURCE: Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Posted on Jan 06, 2008
  • 3 Answers
SOURCE: Polycom soundstation 2W
i saw a post say push 1, 4,and 9 it worked for me
Posted on Jan 11, 2008
SOURCE: POLYCOM SOUNDSTATION 2W
I thought well I wonder what holding down other buttons would do to get rid of this cursed PLEASE WAIT issue.
I tried * and # together and hey presto it worked.
I did however have to go in and turn IP mode off.
Posted on May 05, 2008
SOURCE: Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: transfering call to Polycom Soundstation 4000 on CME
What type of phone system do you have? Is the phone registering with the server?
It sounds like the phone is not registering with the server and the extension does not have voicemail. Need more details to diagnose.
Posted on Apr 02, 2009
What is the ID Message on the polycom soundstation 2w
If you have Polycom Sound Station 2 and you are getting NO ID Message on screen. Please do the following:
1. Press Speaker
2. 773
This should clear up the error.
Mar 21, 2013 | Polycom SoundStation
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
Polycom soundstation 2w has no signal. tel line is good, power to transmitter is good. Soundstation seems ok, can get to menu & settings ok.
Hello Edward,
This is a known issue with this product that requires a software upgrade to resolve. Please download "SoundStation2W Software Upgrade" from the Product Support page of our website and follow the included instructions. If you need any assistance please don't hesitate to call for assistance at 1-888-248-4143 Options 2, 4.
Regards,
James
Sep 14, 2010 | Polycom SoundStation 2W (2200-07800-001)...
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Feb 02, 2009 | Lands Phones
Opening Up A PolyCom Soundstation EX
you have to remove the rubber footings directly under the keypad of your polycom. . . It has 2 screws under those rubber footings.
Sep 22, 2008 | Polycom SoundStation
Adding person to a teleconference group
How can I add 3 other people on the conference call using a Polycom Soundstation?
Jan 08, 2008 | Polycom SoundStation
Dec 07, 2007 | Polycom SoundStation 2W (2200-07800-001)...
Polycom SoundStation Logo
73 people viewed this question
Top Polycom Lands Phones Experts
pankaj rautela
pankaj rautela
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
