Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Aug 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to get the administrator password on my bizhub 350
Hi and thank you for your help : I need to get access in to the TX fax settings but in order to do this I need to get the password in the administrator mode . Do you have this code ? thank you so much.
Anonymous
Level 2:
  • Expert 167 Answers
  • Posted on Aug 05, 2008
Anonymous
Expert
Level 2:
Answers
167
Questions
Helped
197964
Points
292
The default is "12345678" If it has been changed then you are outa luck eh.
Anonymous
Level 1:
  • Contributor 6 Answers
  • Posted on Aug 09, 2008
Anonymous
Contributor
Level 1:
Answers
6
Questions
Helped
20902
Points
23
Cant access tech rep mode
Hi TECH REP MODE IS NOT 12345678 0R 00000000 THESE ARE TO GET INTO ADMINISTRATOR PASSWORDS TO GET INTO ADMIN TO GET INTO TECH REP MODE YOU HAVE TO PRESS UTILITY KEY METER ON DISPLAY DETAILS THEN STOP 00 STOP 01 IN THIS ORDER ONE AFTER THE OTHER THIS WILL TAKE YOU INTO TECH REP MODE...
HOWEVER THIS MODE IS FOR TRAINED CERTIFIED TECHNICIANS ONLY AND IS NOT FOR USE BY HAVE A GO DIY PEOPLE ENTERING INTO THE TECH REP MODE MAY CAUSE DAMAGE BEYOND REPAIR TO NO CERTIFIED TECHNICANS YOU HAVE BEEN WARNED GET TRAINED FIRST
3helpful
Konica Bizhub Password Reset
Konica Bizhub c350 default password is 12345678 give that a try
2answers
FAXING CONFIRMATION
to disable tx confirmation report on a c250
1 press the utility/counter button
2 touch administrator setting
3 enter the password 12345678 and touch ok
4 touch fax setting
5 touch report setting
6 touch tx report
7 touch off
8 touch exit and return back to the normal copy screen
3answers
BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
5helpful
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
1helpful
2answers
2answers
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
4helpful
Konica Minolta Bizbub C253
To output a TX Report after every fax transmission, perform the following:
1. Press the Utility/Counter key.
2. Touch [3. Administrator Setting] on the touchscreen.
3. Enter the Administrator password (default password is 12345678).
4. Touch [OK] on the touchscreen.
5. Touch [7. Fax Setting] on the touchscreen.
6. Touch [7. Report Settings] on the touchscreen.
7. Touch [TX Report] on the touchscreen.
8. Touch [ON] on the touchscreen.
9. Touch [Exit] on the touchscreen to return to the normal copy screen.
Please send posotive feed back if this helps.
Cannot access PageScope Web Connection in client PC
first try to ping this address, to see that this pc finds printer. you have to check network settings for that pc
26helpful
3answers
Print Fax Confirmation
The Bizhub C250 accepts the FK-502 Fax Expansion card like most other Konica Minolta Products so this data is relevant for many models. Below are the step to enable fax confirmation pages:
Press the fax button.
Touch Administrator Setings.
Enter password (12345678) or (00000000) are the defaults.
Touch OK
Touch Report Settings.
Touch TX Report Settings.
Set TX Report to ON.
Close, OK, and/or Exit all the way out.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
