2008 Hummer H3 Logo
Posted on Mar 31, 2011
I GET THIS MASSEG huile a vi danger ON MY CAR Hummer H3
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 31, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
606
Points
I called the car manufacturer listed in the owners manual (2006 Colorado pickup truck, and they didn't know. Roberts Chevy where I bought the truck didn't know either. Does anyone know. It shows up on my message board above the odometer.
Hummer H3 will not start after adding a new battery.
Question edited for better English and all the typos.
It sounds like the vehicle has a night time parking light feature.
https://www.google.com/search?q=Hummer+H3+parking+light
The vehicle won't start because you disconnected the battery. The Security and Immobilizer needs resetting. Number 1 tip, never disconnect the ECM from power even when swapping batteries.
https://www.fixya.com/cars/r29912554-changing_battery_not_create_problems
https://www.google.com/search?q=Hummer+H3+reset+security
Driving and Rpms go up
Dealer Checked my Hummer. They said all H3's have the same problem ...
www.elcovaforums.com > ... > General H3 Discussion
Sep 15, 2005 - 24 posts - ‎17 authors
rattling sound inespected in my hummer because ... go uphill or press on the gas pedal to ... same time up to 2500 rpm on my H3. .... Buzz or Rattle Noise While DrivingUnder Load from the Exhaust ... 2006 Hummer H3
Slow Gear Shift, Low RPM - Normal for H3? - Hummer Forums ...
www.hummerforums.com > ... > Hummer Lineup > Hummer H3
Mar 6, 2012 - Hey All! I recently bought a used 2007 H3 (automatic). ... for h3"!!.if it dont feel normal,,it aint!! im driving my 2nd h3 and they both felt ... 2006 Hummer H3... you can tell when locked up. go ez on gas and rpms dont jump,they ... Hummer H3 Won't get above 2.5 RPM - Hummer Forums ...
Jun 26, 2014
My h3 loses power and sometimes turns off when i turn
Mar 16, 2010
More results from www.hummerforums.com
RPM bouncing from idle. Caused short bursts of "unintended ...
My hummer h3 2008,the oil pressure lindicator
The engine will shut down to protect itself,check the oil level and see whether the car has oil.The light comes on if the oil level is low or the oil pump is not pumping any oil.I replaced my engine hummer h3 two weeks ago due to a malfunctioning oil pump.Check if you oil pump is not malfunctioning.Good luck hope you have not damaged anything further like the bearings due to lack of oil.
Is there a fuse box located inside the 2006 Hummer H3
On this website you find fuse box diagram and description for Hummer H3 (2005 - 2006)
Hummer H3 2005 2006 fuse box diagram Auto Genius
Can a bad computer in an 2007 h3 hummer cause a fuel I injector to go bad?
No a fuel injector can go bad on its own not because of the computer.I have a 2007 hummer H3 and have used 3 engines on the car and the computer has always given me nothing but good service
How much oil goes in the transfer case, automatic transmission? Where can i find this data? please help
The automatic transmission uses 5.00 quarts (4.7L) of Dexron VI when the filter and pan is removed.
A complete overhaul requires 11.00 quarts (10.4L).
The transfer case takes 1.60 quarts (1.5L) of Dexron III
2helpful
What type of transmission fluid do i need for a 2006 h3 and is there a specific coolant?
Transmission fluid - Dexron VI
Coolant - 50/50 mixture of Dex-Cool and drinkable water.
3answers
Can a 2007 h3 hummer be towed behind an rv
not as easy, but possible.. the best ones to tow are a wrangler or any saturn car,or suv..good luck keith...
Top Hummer Experts
ZJ Limited
ZJ Limited
ROBERT GARCIA
ROBERT GARCIA
Are you a Hummer Expert? Answer questions, earn points and help others
