The red line is offset and cannot manually move it using the remote. Using touch focus button give touch focus error. REpair man says it going to cost $560 to repair. He say's the Digital Convergence module needs to be replace and there is no easy way to replace it. red touch focus error. how do I fix it? We are gettin a touch focus error and when we try to change convergance, red is the only one out of line and we can move it left to right but NOT up and down. The problem is much worse on the right side of the screen then the left. Any ideas on things to try or cost of repair or part? Thanks for your help. Michele Mehalovich [email protected]
These sets use STK392-110 voltage amplifiers in the convergence circuit. Chances are good that these are causing your problem. It is best to upgrade these to STK392-150. There may also be some low tolerance resistors that have gone off value. I do not suggest, however, that you do this work yourself unless you have some electronics training. Find yourself a good technician that does component level repair and not board level. The labor will be higher, but the parts will be significantly lower.
You can get repair parts and instructions from www.TvRepairKits.com for this model. Convergence problems are fairly common.
Same issue, however the red will not go side to side. Searching for info prior to calling and asking about service. If I get any other information I will let you know.
Same exact problem! Can anyone recommend someone in the Cleveland, OH area for a repair? Thx. email me: [email protected]
I have the same issue on the same TV. Did any of you folks with the same problem get it resolved? If so, how much was it to repair (if you don't mind me asking)? Lorenzo in Albuquerque
