Check your camera settings in movie mode for the correct settings for time lapse, normal, slow motion and fast motion. A slow recording memory card will not produce your problem but will take longer to save the file. If you shot the movie in PAL and played it on an NTSC TV, the picture would be in black and white with no sound and vice versa. ALWAYS format the memory card in the camera, never on a PC
SOURCE: memory card error in powershot SD1100
Try a retailer near you to see if they will allow you to test your camera with a SD card from a display camera.
Good luck, I hope this helps!
Gom
SOURCE: Canon camera won't accept SD memory card
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
SOURCE: Need Canon Powershot SD1100 IS accessories
Battery and charger here http://astore.amazon.com/hubp0336-20/detail/B0017R6QGM
USB cable to transfer pictures to your laptop here http://cgi.ebay.com/USB-2-0-Data-Cable-for-Canon-Powershot-SD1000-SD1100-IS_W0QQitemZ390092684083QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item5ad355fb33
Good luck!!
SOURCE: Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
SOURCE: Cannon powershot SD1100 IS it displays the
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
