Replace the battery in car with different brand like example {venom}. I had same problem no response. you will have to change the battery connector on buggy to match the new battery.on the battery size you can get 7.4 volts or8.4 volt..
Try sync it on level 4 it is a bad discharge battery I had to sync it after the battery fully charge again max on battery for punch is 4 level in a 3000 stock battery try this first higher level better battery discharge 1 green neutral 2 green foward 3rd click reverse
SOURCE: Novatech High Speed HSP Brushless 70A ESC for Cars, Buggi: wont reach top speed...
The green light wont go solid. .right? so not full speed
Its something wrong with the remote controller, not giving the full speed signal . either change both Tx - Rx crystals . or change the remote. .
but before that try to trim the throuttle on your Rx
