You can get 2 types of Jacuzzi baths, 1 with just a pump which just jets the water via a small pump or 1 with the pump and elements that heats the water aswell as pumps the water through the jets. Because the 1 with the elements has a higher amp rating you need to run a cable from your distribution board to your bath but the 1 without the elements you will be able to tap off the nearest socket to the bath, you will be coming from your socket to a fused spur outlet, it would be better to get a switched fused spur outlet as you will be able to isolate the bath when not in use just by switching off the switch. from the spur outlet you will be wiring it into your motor on the bath, it should say the rating of the pump in amps on the tally plate of the motor or on the manual. For example if it says the motor draws 2 amps you will be putting a 3 amp fuse into your spur outlet so if there is a fault with the motor the fuse will blow instead of tripping the whole socket circuit. All jucuzzi baths has to be connected to the RCD side of your distribution board. If you are tapping off a socket don't worry about the RCD because all sockets should be on the RCD anyway, to check that the socket is connected to the RCD plug something into the socket you are tapping off of and press the test button on the RCD, the RCD should trip and while this is tripped check the lamp or whatever you plugged in shoud be off. The Fused spur should be fitted outside of the bathroom.
Which timer?: Wide variety of Pool and spa controls at Aplus
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
http://www.aplussupply.com/intermatic/timerpool.htm
If you need more help, re-post electrical details about your jacuzzi and exactly what you want timer to do.
