I am setting up my samsung TV (crt type) but it can not get any local channel here in Binan, Laguna, Philippines. I bought the TV in Saudi Arabia & I was told that it will work in the philippines as well.
Start by looking behind the washer and unplug it first. then there will be a water type valve (like the ones outside your house/apt). Turn both of them Clockwise. This will definitely shut the water off! Riyad should have all the Major Manufactures there locally to service. If you are associated with the Military Base. They have service centers there that can help you. Saudi Arabia is quite developed. Probably won't get a Saudi person to service. (Below them!). Probably have to get a Pakistani Guy to do the work!
Hello
You just goto the system option, through its menu, and set the system to auto. I don't know about the transmission system in Phillipenes. Changing system to auto will allow the TV to receive any system transmission. Ok
Was it in a pool or fresh water if fresh just open and let the psp dry by the water evaporating. if pool or salt water sorry there is no way that the PSP can be fixed
switch tv on the switch can not contribute to that. unless the following goes fault
i switch getting fixed on one position(holding)
ii check power on a input of tv and input fuse
iii power supply, i have said that because if a power supply is ok, sound was going to be there.
