Norelco 7737X Electric Shaver Logo
Posted on Mar 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need replacement heads for my 7737 razor. What is the replacement heads for the q177 which are no longer available?
shaveroutlet.com
Level 3:
  • Norelco Master 1,652 Answers
  • Posted on Mar 30, 2011
shaveroutlet.com
Norelco Master
Level 3:
Answers
1652
Questions
0
Helped
765245
Points
4209
HQ177 replacement heads have been discontinued and replaced by another part number. You will find the new replacements from shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
Testimonial: "right on thank you"
Anonymous
Level 2:
Guru:
  • Expert 174 Answers
  • Posted on Aug 26, 2012
Anonymous
Expert
Level 2:
Guru:
Answers
174
Questions
0
Helped
106828
Points
179
Replacement heads for norelco 7737x is philips norelco HQ177 replacement blades.
I'm looking for replacement heads for my 45 to 60 year old Norelco Electric Razor type HP1122. Can they be replaced?
Question edited for clarity.
Two questions merged to one.
Duplicate question deleted, refresh page to see your question.
some Norelco spares are available
https://www.google.com/search?q=replacement+heads+for+my+old+Norelco+Electric+Razor+type+HP1122
Philips norelco sensotouch replace the shaving unit. replace damaged razor heads
You will find RQ11 shaving heads at shaveroutlet.com at the link below
http://shaveroutlet.com/philips-norelco-rq11-sensotouch-replacement-heads.html
Razor is not cutting
When the shaver is no longer cutting properly, this usually means that the heads need changed. You will find replacements for model 7735X at shaveroutlet.com. See link below<br /> <br /> <a href="http://shaveroutlet.com/norelco-philips-hq177-cool-skin-replacement-heads-p-245.html">http://shaveroutlet.com/norelco-philips-hq177-cool-skin-replacement-heads-p-245.html</a>
My razor blade heads no longer rotate but when removed the mechanism underneath is spinning normally - the razor is clean and fully charged.
It sounds like your heads are damaged and need replaced. You can not repair theheads if damaged. You will find replacements for Arcitec shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
2answers
I need a replacement shaving head for norelco 7737x, not just the blades but the entire shaving head.
Here's a source for the replacement heads and cutter blades for your Norelco 7737. If you need any other parts, they also have them available.
http://www.electricshaverstore.com/get_item_hq177_norelco-cool-skin-7000-series-head-set.htm
Hope you find this Very Helpful and best regards!
2answers
The razor head comes loose from the two arms.
I had a similar problem where one of the side covers popped off. I was able to reattach it, by carefully aligning the spring and pushing back into place. If you've lost the pin, you're out of luck. Braun does not make these kinds of parts available for user servicing, unfortunately.
However, the 7000 series models are all compatible with each other in terms of motor, battery, and razor head armature. You could try locating a moderately used example on the cheap (maybe less than $20) and then cannibalize it for the parts you need.
Do NOT send it off to Braun for servicing, as you will be charged much more than the shaver is worth. If it comes to that, you're better off just going with an 8000 series shaver.
Doesn't hold a charge or cut very well anymore
Heads for your model are no longer available. Shaver will not hold a charge because batteries need replaced. Batteries can be replaced but soldering is required. If you have cleaned it well and it does not cut, I suggest getting a new shaver.
A full line of Philips Norelco shaver can be found at shaveroutlet.com
ShaverOutlet com ShaverOutlet com Rotary Shavers Men Shavers Manufacturer...
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
