Hi cinlytan,
With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
Hope it helps.
Thank you for using Fixya.
Canon Printer Error Code 6000 is one of the most common errors which rises quite often. It seems when users attempt to print any papers on the Printer. The Paper jam issue is the main reason behind this error.
Reasons that cause Canon Printer Error Code 6000-
1. The feed tray of the printer is improper fitted.
2. A large number of documents near the printer.
3. The line feed is scratched or smeared.
4. Giving multiple paper print commands at once.
5. Faults within the sensor unit or in-line feed slit.
Along with the highly advanced features, still, some users get trapped with the Canon Printer Error Code 6000. So, here in this section, we have provided an easy solution to that error.
Many ways can be followed to fix the problem of Canon Printer Error Code 6000. if you want a perfect & right solution recommended by an expert. follow the blog steps.
