I can not find out how to replace the printer cartridge
Replacing the print cartridges
The print carriage will move into the access area.
Figure 1: Opening the print-carriage access door
NOTE: The black cartridge is on the right side of the print carriage.
Figure 2: Removing the print HP PSC 1300 All in one Printer - c00034851.jpg
NOTE: It is normal to see ink buildup in the print cartridge slots.
CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
CAUTION: Do not attempt to push the cartridge straight into the slot. It must slHP PSC 1300 All in one Printer - c00034853.jpglight angle.
Figure 4: Inserting the print cartridge
Using a pHP PSC 1300 All in one Printer - gtabtop.gifcartridge
To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Figure 5: Storing the print cartridge
1 - Inserting the print cartridge
2 -HP PSC 1300 All in one Printer - gtabtop.gifhe print cartridge
Aligning the print cartridges
After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
SOURCE: hp psc 1300 printer cartridge
The 'check print cartridge' light keeps flashing on my HP printer, so I replaced the cartridges and everything else i could think of such as restart my computer, temporarily disconnect the printer, etc. the light continued to flash. I also tried resintalling the printer software. Any ideas??
SOURCE: HP printer PSC 1410 ALL in one printer showing "Check print cartridge" error
Turn your printer off and turn it back on.
SOURCE: HP psc 1300 printer
this printer does not print on photo paper...read the specs online about it....prints on regular stock paper but NOT photo paper....i have the same prob.....need to buy a photo paper compatable printer.
SOURCE: replacement ink cartridge not printing
this has various reasons that this problem occurs.but the 1 simple solution is to get it properly work is to uninstall the printer driver and then reinstall it properly.this will definately work.
please let me know what is rail and carriage bushings ?
HP PSC 1300 All in one Printer problem
I'm inserting at an angle, but I can't get cartridges to click into place.
I have the some problem It don"t print and show information "HP Print Utility error. I have HP 1350 All in One print test program and it show me all is OK.What to do?
