The coupler nut tends to be screwwed on so tight that even when undone, the collet has bit into the soft shaft of the tool. Holding the rotation lock button in, grab the shank with some strong needle nose pliers and twist the shaft loose or pull it off completely with the nut and then seperate the nut from the shank when it is out of the Dremel Tool. A lot of machine tools are tightened too much, which makes the shanks get all damaged so use only the required tension on that collet nut.
