I have a Dell MFP 1125 and eveything works except incoming fax and the code comes up rx comm. error. The fax does not come through. Just bought the 4-1 Dell from another party. Does anybody have an idea? Is something wrong internal or just need to adjust something?
Jerry
Jerry
You can't post conmments that contain an email address.
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
hello there here is several links that will help you out ok best regards michael
RICOH AFICIO220ServiceManual
RICOH AFICIO220 - It's a complete servicemanual, and it's in PDF format. ... i got my servicemanualfor philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
Try sending a test sheet using "hook" to a known good fax if it goes the fax is fine (it wont leave the doc feed till its coming out on the rx. fax.) If this works then maybe the speaker is bad or disconnected. As for the report you need to chance the transmission report to off or error.
-Carl, please let me know if this helps.
Sending faxes and revieng faxeng through a pbx you need te configure the pbx and youre fax too.( Dail a 0 before youre messages! ) You have to connect always on the pstn line on the 210sf even if you use a pbx.
The Ricoh spc210sf isn't supporting an pbx on isdn line!! Watch out for this because the isdn line is working on 24Volts!! Then you can blow youre fax modem of the spc210sf .
You can contact me true email= [email protected]
Let me know is you encounter new problems?
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit area If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line. Adjust the Tx levels of the communicating machines. See code 6-05.
6-05 G3 ECM - facsimile data frame not received within 18 s of CFR, but there was no line fail Check the line connection. Check connections from the NCU to the FCU. Check for a bad line or defective remote terminal. Replace the FCU, FCU or NCU. Try adjusting the rx cable equalizer Cross reference Rx cable equalizer - G3 Switch 07 (PSTN), G3 Switch 08 (PABX)
Jerry
