Question about Brother Dcp395cn InkJet Printer
My brother printer DCP 395CN does not give option of printing odd or even pages in fast or fast normal mode. When i switch to normal printing mode it provides option. I want to print pages on both sides with fast mode as normal mode takes too much time and ink please help me.
    Guru:
  • 250 Answers
Some printers automatically print automatic duplex printing, other printers allow you to manually reinsert pages to print the second side .and some printers do not support duplex printing at all.
To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box
Note that If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
Posted on Mar 28, 2011
SOURCE:
How do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Apr 02, 2015 | Brother DCP-8045D All-In-One Laser Printer
I can't set some printing options
Hi Jarosaw,
Change Your Brother Printer Setting Go To Below official Brother Printer Page For Your Problem:-
Change the printer driver settings For Mac OS Brother
Still having Problem Then follow Us For
Brother Printer Support
Feb 23, 2014 | Brother DCP-J140w Compact Color Inkjet...
Poor quality print for brother dcp 185
Machines of God will solve your problem add me on msn i weslley_lobao@hotmail.com
Aug 02, 2012 | Brother DCP 165C Compact Color Inkjet...
Tel me the processedure of duplex printing
Dupoles printing can mean different options in different hardware and software. It can refer to two pges condensed to one A4 in landscape or it can mean odd and even pages on two sides.
Most office suite packags give you the option of duplex in the same way leaving the hardware unchanged which is the best option oveall.
You can printy all ODD pages then reinsert and have it print even pages on the other side and then all you do is colklate them. OR you can print side by side fromn 1- whatever.
By using software option it leaves the printer in its native mode without having to reset ity for the next job
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | HP LaserJet 4250dtn Printer
The print is blurred.
no ink in cartrige...change the cartridge...or
try using print option....like....
fast draft/draft/normal/high qty/max dpi etc...this will be available in ur printer software that's installed in the pc/laptop....try to c if there is a printer icon in the rightbottom of the task bar...near the clock...click that printer icon and u can go into the print options...
Dec 21, 2009 | Brother DCP 115C All-In-One InkJet Printer
DCP-135C printing crooked
Hello! I need help!
My Brother printer - DCP-135C
I've changed all inks include the colours.
I able to print the Red, blue and yellow. But I can't print the Black.
I've tried pressed the cleaning option for many times.. Please advise some help.
Rgds, V
Jan 17, 2009 | Brother DCP 130C All-In-One InkJet Printer
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Brother DCP-135C Print Quality Settings Not Working Correctly
Have you uninstalled the driver, and reinstalled it?
Are you running Windows Vista? If so, have you downloaded the latest software from Brother's website? www.brother.com
It sounds like the driver is confusing the settings internally, which leads me to think that it is either corrupt or not compatible with your operating system.
Apr 19, 2008 | Brother HL 1440 Laser Printer
Print Odd or even pages only
There is no option in the printer to chose eve or odd pages bout if you print under windows environment you can do that from the able cation example if you use Microsoft world go to file chose printer then chose eve or odd from print comp box
Mar 12, 2008 | HP LaserJet 4050tn Printer
Paper jam
could your problem be room humidity? in fast, the paper doesn't have time to get saturated with moisture. see if the rollers that feed the paper are making contact with the sheet. perhaps the bottom idler roller isn't coming up far enough.
Sep 10, 2007 | Brother DCP 115C All-In-One InkJet Printer
Brother Dcp395cn InkJet Printer Logo
188 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
