SOURCE: Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
SOURCE: what is the interlock for a staples shredder
if you look at the underside of the shredder, you will likely find a pressure switch that is actuated when it sits on the stock bin, either modify it to touch when on the new bin or secure it so it is depressed all the time. This should allow it to operate on the replacement bin.
Hope this is of some help.
Ed
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
