Karcher 2500 PSI Pressure Washer Logo
Posted on Aug 04, 2008
ONE OF THE SPRAY HEADS IN PATIO ATTACHMENT SEEMS BLOCKED
Anonymous
Level 1:
  • Contributor 33 Answers
  • Posted on Apr 21, 2009
Anonymous
Contributor
Level 1:
Answers
33
Questions
0
Helped
18476
Points
61
Simple. find the smallest drill bit to fit the hole and run bit thru it. wala.
2answers
My vax upholstery attachment won't spray water
Blocked jets or blockage in water line to hand held
Aug 19, 2021 • Vax Vacuums
2answers
Can I use spray paint in my back yard?
Sure, why not?. I've sprayed kitchen cabinets in my driveway, dining room chairs (metal, with auto paint) on my patio, wood paneling and more.
I would suggest using drop cloths or plastic to cover whatever you're not spraying, as spray will spread, especially if you use a water-based paint.
Hi I have the Gas Patio Caddie. The coating that is in the inside of the cover is bubbling up and starting to peal off. Can that be resprayed with something or do I need a new cover? If so where can I...
It can be repainted, using spray on, High Heat Grill Paint. Which, you can find at any home center or hardware store, in the paint department. Krylon makes one, as does Duron. I personally like Krylon, as it seems to cover better.
You will need to thoroughly clean the surface of any grease, rust, loose paint, etc. Then wipe the the area to be painted with denatured alcohol and then wipe off any remaining residue before spray painting it. Several light coats is much. much better than two heavy coats. Allow each coat to thoroughly dry, before applying the next coat.
Do not use the grill for 48 hours, after the final coat of paint has been applied.
Hope this helped you and Happy Grilling!!
Wont come clean How can i check if the spray heads
TAKE ARMS OFF THEY DO UNCLIP SOME HOW ...SEE IF THE HOLES ARE CLEAR AND NOT BLOCKED WITH FOOD ECT ... TRY THAT MATE.
Will not spray
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see the small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Won't spray, only dribbles
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see a small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
I have a Patio II and one of the ceramic heads is filthy and clogged. Can I soak and clean this baby rather than mortgage my home for a new one ? :~) Thanks...David
You can try to remove the parts, soak them in Simple Green, wire brush with a tooth brush or brass wire brush. Should work just fine.
Right side burner failure on TEC Patio II
the mesh could be split or blocked burner needs cleaning .
2answers
When the patio cleaner is attached,the Karcher 5.68 pressure washer now keeps stopping and starting.It works fine on high pressure lance.It worked fine when bought from new a few days ago. We tried...
None of these fixes works for me and the original poster, like me what he's saying is when he swaps the high pressure lance for the patio attachment it pulses on and off, but when that happens, you can swap back to high pressure lance and it's fine. This means it's the patio attachment not any valves or power source, I have the same problem
TECH II CERAMIC BURNER PROBLEM
just removed ceramic burners on my patio II-had to grind heads off of stainless stee bolts[ 4 on each burner],bolts do not have nuts instead they have theaded collers which have deteriorated and turn when i turned the bolt.used a 4" angle grinder-remove gas cylinder before attempting this!
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
