Huffy 26 in. Cranbrook Cruiser Bike Logo
Posted on Mar 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I sit on bike and pedel bike will no go pedels seem like there stripped just spin something wrong with pedel bearing maybe
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Mar 27, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2767888
Points
24828
If it spins wihout spinning the rear wheel there is something not catching (chain, internal mechanism of the rear hub maybe). You need to LOOK at it and determine if the rear cog is indeed spinning with the chain or not. If it is spinning without the wheel the pawls or guts are not engaging. Take it to a Bike Shop and have them assess it.
Necchi foot pedel just hum's doesn't work, why?
if your machine has this slide button on the motor casing maybe you need to switch it back and forth a couple of times
NORDITRACK GX 4.7 RECUMBENT BIKE THE PEDELS ARE SLIPPING AND THEN KETCH BACK UP, HOW DO I FIX IT
It's the clutch bearing in the brake assembly. They can be replaced but you would need a bearing press. Might be better off buying a new assy.
2answers
What causes a bike to be hard to pedel?
id say Hill's is number one on my list . then they go down in importance - gears- brakes- bearings- oil loss
Oct 13, 2016 • Cycling
Console will not power off automatically on the gx 2.7 bike
Hi Kim:
Since this is a new bike I would not waste any time trying to find out what is wrong.
I would take it back to the dealer or store where it was purchased and ask for a replacement.
Sticking brakes
well i have one ideal on the brake pedal there should be a spring to make the pedal return.......maybe the spring needs a bit of wd40 or something similar.....if you get any dirt or grit in the brake pedel works may this is causing the trouble..........
My 96 sunfire was sitting a long time before i bought it. It drove fine the first 100 miles. i thought the clutch was going out bc i had to push the pedel to the floor so the gears would engadge. When i...
Your losing fluid somewhere, it is a hydraulic clutch so this means hydraulic fluid powers it. Bring to transmission shop for repair.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
My stop lights wont go off. Stay on all the tima.
There is a button above your brake pedel that probably isn't being pushed in all the way by the brake pedel to shut them off. Try pulling up on the brake pedel and have someone watch to see if they go off when you do that. If so the button for the brake pedel needs to be adjusted so it shut them off when the pedel is not pushed.
What causes my mongoose freestyle girls 20" hard to pedel?
Could have sticky or seized up crank bearings where the pedals are or the rear wheel bearings. Have you tried pedaling and spraying a lubricant where all the bearings are or remove and re-grease the bearings?
Clutch keeps coming out
if you mean the clutch doesnt engage until the pedel is nearly all the way out (up) .. then there is an adjustment for that called "free pedel adjustment" .. its usually a 5 min job .. however if there is any clutch chatter or noise then you may need a new clutch plate ... a bigger job ... one way to burn up the clutch plate is to allow it to slip for a long time ... and thats what will happen if the free pedel adjustment isnt done soon ... if your problem is not that then maybe you can expain more ....
Top Huffy Cycling Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
