I have the V4500 and after running for a while, it starts whistling. I think condensation drops fall into than and create the whistle. Any suggestions?
I don't think they want you to open the motor housing as it could cause them problems. This unit was not intended to do the job your asking it to do and you should consider a humidifier for your home or apartment. they can be added by a HVAC man and are not to expensive. I think this would help you with both your problems.
Or put some CLR threw the motor and it will clean it up.
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
i know why. clean the small long tubular thing that is sucking the water. put a q tip in there and get the gunk out. thats what you need to do -- try it and let me know if it worked. [email protected] it worked for me!
the white film is just dust particles from the unit. it's also a bit of condensation that is building up. the particles are not harmful. but it's nice to keep it clean after every use. also the film is coming from the vicks. that is normal. so nothing worry about as far as harming the childs air or anything.
You may be having problem with air scaping from the base of the hum. it will probably may have to put silicone around the base of the hum. to stop the air scaping.
