If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
SOURCE: whirlpool LSR6333LQ0
ALWAYS CHECK HAVE SOMEONE WHO KNOWS ELECTRICAL APPLIANCES CHECK YOUR APPLIANCES. ALWAYS CHECK "WASHER DOOR SAFTEY SWITCH" IT COST UNDER $20 Joe_Rex
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
SOURCE: washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
