If you go to www.partsdirect.com you should find the answers you need
Water Filters Lawn Garden Appliance Parts
SOURCE: have a trouble: dish-washer will not drain.
bear in mind first program action is drain but at this point there should be only a small amount of liquid in machine.check spigot is free by pouring a little water down it. blow thro drain hose to check free as well - you can get a fat blockage in drain hose. if both are free you may have a blockage in exit to pump.the only other maintenaince is to use a dishwasher 2-3 times a year
SOURCE: cleaning the drain of a bosch dishwasher
had the same problem if you remove t20 screw on the left side of the bottom bowl & remove plastic cover this is the drain pump & can block with food or glass particles clean it out & check it revolves & should be ok
SOURCE: Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Daniel
Hi
Dishwasher not
draining issue usually occurs due to kinked drain pipe, clogged drain filter or
drain pump. Check the drain hose for any visible clogging, remove if present.
If no visible lint is present then remove then turn off the dishwasher and remove
the drain hose and check for any visible clogging. If still not visible then
the drain filter or drain pump is clogged and you'll need to clean the drain
filter and drain pump. Also, check for any food pieces stuck near the pump
impeller.
Please note that
dishwashers don't drain out the complete water such that heating element
doesn't overheat.
Hope this helps...
Daniel
Hi
Dishwasher not
impeller.
Please note that
doesn't overheat.
Hope this helps...
Daniel
Hi
Dishwasher not
impeller.
Please note that
doesn't overheat.
Hope this helps...
Daniel
