Idk y it sent me to this i was hoping to get a new title but the radio i have is the p7700mp i keep gettin this error ao displayed on the led's when playing cd's only fm/am radio work, cd gets stuck and will not come out unless i pull the faceplate out put it back on then hit eject. if i put the cd back in it will most likely display it again and sometimes it will just play. can anyone make any suggestions....... im thinking ive just had it too long and maybe the lens is dusty or something but then again it does play most the time????? someone pls help
If the discs PHYSICALLY get stuck, then the mech is damaged. A local shop MAY be able to fix it, but it might be a better investment to just replace the radio.
Yes. If the discs do not freely go in or out, then the MECHANISM that controls these actions is damaged/misalligned/jammed/dirty/ etc......
I see... when you said "cd gets stuck and will not come out unless i pull the faceplate out put it back on then hit eject", I thought you meant it got stuck inside. Well, if it loads/ejects fine, then yes it is either a dirty or dead laser. You could try gently swabbing the lens with a Q-Tip and rubbing alcohol and then immediately drying it with canned air. If that doesnt fix it, then it's likely time to replace it.
the "mech" is damaged?????
oh no it goes it and comes out freely no problem with that. just sometimes i get that error when playing cds my guess its maybe my lens and i would open it cus im handy like that and it doesnt have any type of warranty but i wanted a second opinion to see if it was something else so i dont waste my time.
